It is currently Thu Aug 14, 2025 1:07 am
PostPosted: Thu Oct 29, 2015 9:19 am
First name: Eric
Last Name: Schaefer
City: Bernville
State: PA
Zip/Postal Code: 19506
Article discussing the uses and pros/cons of different types of clamps in guitar making:
http://www.ericschaeferguitars.com/clamps-how-many-is-too-many/
These users thanked the author ericschaeferguitars for the post (total 2): unkabob (Thu Oct 29, 2015 6:39 pm) • qrwteyrutiyoup (Thu Oct 29, 2015 10:28 am)
PostPosted: Thu Oct 29, 2015 5:06 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
I never heard of anybody having to many.
PostPosted: Thu Oct 29, 2015 5:34 pm
Conversely, I don't have many at all. I have four 12" jorgenson clamps, 6 spring clamps, and Stew Mac's deep ibex clamp for the brideg. I'd love to have more, but they're pricey and I haven't run into any issues.
I clamp my braces and glue the top and back to the rim in the go-bar deck. The clamps I have are fine for clamping the neckblock, heelblock, and headstock overlay. I use a radius block and a neck caul to glue the neck to the fretboard with the clamps I have on hand, and have Stew Mac's bridge clamping caul. Other than that, there aren't many clamping operations I can think of.
PostPosted: Thu Oct 29, 2015 5:57 pm
First name: Patrick
Last Name: Hanna
State: Missouri
We can break a lot of our processes into sub-processes that allow us to use fewer clamps. In my view, go-bar decks count as clamps (but I know that's not the subject of the thread).
I suspect we should investigate the various types of clamps we need before we can answer the overall question. I mean....a thousand spring clamps would be a thousand too many if what you really needed were three bar clamps.
PostPosted: Thu Oct 29, 2015 6:13 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
How many is too many?
If you can't fit any new tools into your shop because of all the clamps, then you have too many clamps.
PostPosted: Thu Oct 29, 2015 6:49 pm
City: winnipeg
State: manitoba
Country: canada
I use spool clamps made from 1/4-20 threaded rod , 1 1/2 X 1 1/2 X 3/4" blocks using a plate-nut and a wing nut. I have always wanted to round the corners but I haven't managed in ten years. A cork face would be nice but the melamine seems to work well.
Bob :ugeek:
PostPosted: Thu Oct 29, 2015 7:58 pm
First name: D
Last Name: S
I've been buying the 6" screw clamps from Harbor Freight on sale for $2.99 ea.
They are really good clamps, better than the Irwins I have.
I buy all they have when I go.
Funny, the last time I glued a drop top on a solid body, I could have used two more.
So, I reckon I don't have enough yet.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Oct 29, 2015 9:22 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Clamps? Too many? You jest. No such thing.
PostPosted: Fri Oct 30, 2015 1:34 am
1 more than you need at the time.....that's too many :D
PostPosted: Fri Oct 30, 2015 11:59 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
How many clamps is too many?......nobody knows!!
PostPosted: Fri Oct 30, 2015 3:54 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Not that I would ask, but I'm sure my wife could answer that question! :?
Alex
PostPosted: Fri Oct 30, 2015 6:00 pm
These users thanked the author Rod True for the post: David Malicky (Sun Nov 01, 2015 12:33 pm)
PostPosted: Fri Oct 30, 2015 9:48 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Rod, I got verklempt looking at that photo
These users thanked the author Mike OMelia for the post: Rod True (Sat Oct 31, 2015 10:05 pm)
PostPosted: Sat Oct 31, 2015 9:32 pm
Last Name: Sollod
Is this too many?
www.swiftcreekguitars.com
PostPosted: Sun Nov 01, 2015 5:18 pm
Rod True wrote:
Looks like two and a vice are enough!
PostPosted: Mon Nov 02, 2015 9:14 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Building a sailboat in the 70's, my brother and I ordered Sitka Spruce for a mast in "spar grade" which is allowed to have pin knots of a certain size and spacing. Maurice L. Condon (still in business) called and said they did not have spar grade in that size, would we accept "aircraft grade" as a substitution - this is the grade that was used to hold on wings of planes and was not allowed to have much runout, let alone knots. Of course we said yes.
Then the problem of clamping a 9" assembly - we had to borrow all the clamps of that size that 3 other home boatbuilders had - a total of 140 if I recall:
https://www.flickr.com/photos/ruby1638/22697323352/in/album-72157644804469517/
So the answer is - it takes 4 amateur boat builders to get enough clamps.
Looking at that mast now, 36 years later, there are some guitar tops in it - one small area has 63 grain lines per inch.
Ed
